Old 12-16-2019, 04:56 PM   #1
Pull out stuck
Rockwood 8280WS 5th Wheel living room slide moves out a few inches and then the gears grind and it won’t move further. It seems that one side moves more quickly. We have owned the unit 6+ years without issues. Any suggestions?
Herman is offline   Reply With Quote
Old 12-17-2019, 09:06 AM   #2
Commercial Member
ES_FR's Avatar
Herman,
We would be happy to assist you with your Rockwood. Because your ongoing satisfaction is very important to us, we invite you to contact Rayna Dimitroff in our Customer service department through the following personalized and direct link: http://www.forestriverinc.com/Direct...21702967940134.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 12-17-2019, 10:39 AM   #3
Head Rambler
Does your RV have the thru-frame slide (gears under the floor) or does it have a Schwintek slide (gears on the sides)?
If it's a thru-frame slide it could be a sheared pin/bolt or it could be a stripped gear.
Gotta go campin!
