Originally Posted by awellis3
Then you need to go solar (more expensive than a generator) or give up using electricity. However, if you only camp one or two nights at a time, adding a second battery could solve the problem.
Not necessarily more expensive. There are some good suitcase units on the market that will provide charging whenever the sun is out for ~$300. No, they aren't huge power sources but you'd be surprised on how much power can be replaced with a 5-8 amp charge rate over 5-8 hours of sunshine.
The difference between a low charge rate from a solar setup versus higher rate from a generator is that you will be more inclined to leave the solar "suitcase" setup all day and night for the duration of your camping stay versus being reluctant to turn on the generator "too early" or let it run long enough to fully recharge. Often one won't run the generator every day, waiting until the batteries are more depleted whereas a solar setup charges whenever there is sun providing power and the battery is needed.
Think if it like two large water tanks. One is being filled from a garden hose that runs all the time and the other is filled by a pump that only runs a few hours per day. A lot more water has to be pumped in a short time to make up for the water used while the hose has been filling all the time, even when water isn't being used.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
