Old 06-24-2020, 09:56 PM   #1
Roller failure
Just came back from a weekend trip where one of our 6 slide out rollers failed. We have probably extended the slide out a total of 20 times in the last 3 years. (8200 miles on our 2018 MBS 2400W total. ) We had one of the rollers fail and it cut into the slide out. We fortunately got lucky and were able to retract the slide at the end of our trip. I think I found the correct replacement below. Do you all carry a spare or just hope they don't fail? I have lost confidence in this unit and don't want it to fail in the middle of nowhere.
https://www.etrailer.com/Accessories...95-000179.html
ID:	232334   Click image for larger version
browser5031 is offline   Reply With Quote
Old 06-24-2020, 11:48 PM   #2
NXR
NXR's Avatar
What do you mean by “failed”? It looks intact. Seized up or what?
Forest River can supply stainless steel plates that sit between the roller and the slide or you can get them manufactured locally. They distribute the weight better and if you have a roller failure the stainless steel will help,protect the slide bottom.
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 06-25-2020, 12:02 AM   #3
Sorry I should have been specific. Looks like the internal bearings failed. the white nylon plastic is still intact but I think the bearings failed because the slide out now is scraping on the black metal behind the roller. The roller is now sitting below the black metal plate, where the other 5 rollers are above the metal plate.
Old 06-25-2020, 12:10 AM   #4
Thanks NXR, I have been looking at postings of guys that put sheet metal under there. Definitely going to get some sheet metal locally and put it on the underside. Again I got lucky this time, but the wife and I were planning on a trip to North Dakota in about a month and I don't want to get stranded somewhere out there if another one fails and we can't close the slideout.
Old 06-25-2020, 07:28 PM   #5
NXR
NXR's Avatar
It's not really sheet metal. It's fairly thick and they are quite heavy. Sheet metal likely would just dent.
Ray
