Old 07-07-2020, 02:32 PM   #1
Seals for Slide Outs
Hi, I'm new to the forum and to trailers with slide outs. I have a 2004 Flagstaff 26' super lite. I bought it for camping on my property in East Texas. Some of the Wipers and Seals on the Slide Out are a little tore up. I found the Wiper and D seal part numbers pretty easily, but am having a devil of a time with the seal that attaches to the slide out itself on the inside. It looks like a piece of rubberized fabric 6-8 inches wide,
Does anyone have a name for the seal or a source for the material?
I've tried Steele Rubber and Camping World, but nothing matches.
For anyone looking for seal and wiper part numbers, I'm using a 7/8 bulb with domed channel P/N 70-3835-265 and a peel and stick wiper seal with track P/N 70-3835-265. I've watch the YOUTube videos and the replacement looks straight forward, just need the material for the inside. Thank You in Advance
ID:	233375   Click image for larger version
ID:	233376   Click image for larger version
ID:	233377   Click image for larger version
webert1316 is offline   Reply With Quote
Old 07-07-2020, 03:15 PM   #2
Last year I had replace the same type of seal. I went to a RV dealer and they wanted to order like a 30 foot minimum. I only needed to replace one side which was about 6 feet.
I forgot how much it cost to order and if it was the right size and type, but I passed up and went to another dealer. The second dealer had the exact seal and cut off the exact length that I needed. They had it on a very large roll. You can do the same. Cutoff a small piece for a sample and go to RV dealer. Another thing you might do is "google" slideout seal and order over the internet. I did that and came up with a couple of companies that specialize in slideout seals. Try to match up what you have.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 07-07-2020, 03:32 PM   #3
Thanks txredfish, tried google but no joy on the one you got from the dealer. I guess I'll hit the dealers till I find a co-operative one.
seal, slide, slide out
