Old 10-08-2020, 11:20 AM   #1
Should I Worry about This?
On the topper of my rear slide, I notice this rubberish seal (like a string) protruding out a bit. Tried to slide it back into the track it is in with no luck. Looks like to completely reseat, I would have to take the topper off the roller to get to the track...something I have no experience doing.
Here's a closeup pic showing it on the left side and another showing the same look (without any protruding seal) on the right.
Anything I really should do to prevent a future issue here? Thx!
Name:	Topper - Left.JPG
ID:	240771   Click image for larger version
Name:	Topper - Right.JPG
ArkRVHog
2018 Forester Model 2801 QSF
Katy, TX
OTR 2024-22 / 2023-29 / 2022-52
2021-51 / 2020-29 / 2019-71 / 2018-49
ArkRVHog is offline   Reply With Quote
Old 10-08-2020, 01:58 PM   #2
What you need to try is to unroll the roller a little to loosen the fabric and try to slide the rod back into the slot. You may need to take a pair of needle nose pliers to get it to push in. Grab it close to the roller and move it a little at a time.
If you have a strap wrench or something you can rig up as a strap wrench it makes unrolling the roller and holding it a lot easier.
Gotta go campin!
Old 10-08-2020, 02:07 PM   #3
llr
I would check the other end 1st, if it is not pulled in on the other end then it is just extra and either leave it or trim it.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
llr is offline   Reply With Quote
