Old 09-04-2020, 08:47 AM   #1
Slide Adjusting
I am needing to correct my sagging slide. The bottom of the slide has about a 1.5Ē gap between the face and the wall inside.
Iíve looked at the room height adjustment, which looks fairly simple. However, I noted that the slide rails themselves are no where near level. Whereas the camper it self sits fairly level.
Is there any adjustment to be made on the rails or do I just proceed by compensating with the adjusters at the end of the rail?
67vtx1800 is offline   Reply With Quote
Old 09-04-2020, 08:20 PM   #2
This is the exact reason that I joined here. Mine is doing the same thing. I adjusted the threaded rod enough to fix get it a lot better but then when I slid it back in the rear had a gap, so I put it back the way it was. I was going to try to outer bolts too but it looks as if the slide would be too high when slid in if I adjusted it up.
chrisarrington is offline   Reply With Quote
Old 09-05-2020, 08:43 AM   #3
Thinking about this last night. I'm thinking the reason that it didn't close once I got the extended position fixed is because I didn't adjust the stop can. I may try to adjust it all out again and see if I can fine tune it.
slide
