Originally Posted by RAR
Thanks any problem with it getter gummed up?
Stick with any "Dry Lube" or one that dries to a non-sticky surface and no gumming up problems.
Any lube that leaves a greasy surface will attract road dirt like "fly paper" and you could end up with a sticking problem which could result in clutch damage or blown fuses (depending on slide mechanism).
