Use a silicon spray lube that will not attract debris to the gears and rails for the slides. You will also want to spray with a seal conditioner for the seals on the slides. I do this twice a year once in the spring and once in the fall.
For wheel bearing grease I use NAPA brand grease for wheel bearings. This is in a tub for easy application. I also used this on my king pin around the hitch jaws.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
