Titan Mike,
Thanks for your clear reply. That was the best explanation of how the slide actuator works. In my research on this forum and from Lippert manuals etc, they talk about slide out adjustment but no one mentioned the fact that the "out" adjustment is limited by the actuator itself and the "in" adjustment by the location of the stop can. Your explanation was right on and is the way I figured it had to be.
Also there is lots of discussion about whether or not the motor/actuator has some sort of clutch. Some say don't ever hold the button till you hear the ratcheting sound. I have a 2021 Minilite 2104S and my slide is powered exactly like you said. While I do let off the switch immediately when I hear the ratchet, I no longer am afraid that it is stripping some gears. I am currently having a problem where once I pull in the slide and hear even "one" ratchet sound, I then need to manually turn my crank just a half turn to get it started going out and then it moves out under power just fine. If I try to move it out before using the manual crank for half a turn, I hear a lighter clicking sound (not the heavy ratchet slip clutch sound) and the slide will not move. I found another very long thread on the "Grand Design RV forum" that went into great detail of someone that had a similar problem. I am still deciding if it is the motor or a poor connection or some binding at the end of travel that is causing it. BUT in the process, I needed to understand how the actuator worked and your post did that very well. Thanks.
Keith
Rockwood 2021 2104S MiniLite
2018 Toyota Tundra SR5
