Old 09-09-2020, 06:39 PM   #1
Slide out fault
Hello! I found a thread on here that has my exact problem but it didnít show a solution. I could not reply due to the thread being to old. Anyways, Iím having a slide issue. The slide will start to come in (or go out) and one motor stops and then the other quickly behind it and then nothing. The controller says itís a short between controller and motor. Any solutions for this issue would be greatly appreciated!! Thank you!
SCJones23 is offline   Reply With Quote
Old 09-09-2020, 08:53 PM   #2
bikendan's Avatar
Is it a Schwintek slideout system, with two track rails on each side of the slideout?
Old 09-09-2020, 09:07 PM   #3
With it fully retracted - if possible- swap the motor 1 and motor 2 plugs at the controller.
Old 09-09-2020, 09:33 PM   #4
Yes it is
Old 09-09-2020, 09:34 PM   #5
I can try this tomorrow. What should I be looking for?
Old 09-09-2020, 11:57 PM   #6
bikendan's Avatar
Originally Posted by SCJones23 View Post
Yes it is
Have looked at the many Schwintek troubleshooting videos available?
Old 09-10-2020, 08:11 AM   #7
The controller will have 2 plugs, one for motor 1 and one for motor 2. Try swapping those. The controller will also have 2 spade terminals for in/out- dont swap those.
Old 09-10-2020, 08:15 AM   #8
Itís possible that simply unplugging them and then reconnecting them will work. The two slides run by the controllers you see there were doing what you describe. I was getting a 2/8 error code on both of those- short in motor 2 wiring. I swapped to see if I would then start getting the same error code but now showing as a motor 1 error( what should happen if there actually is a short in the wiring or motor) and theyíve worked perfectly since.
Old 09-10-2020, 08:19 AM   #9
Another note- I had the slides both lined up properly when I swapped, which is why I recommended you have the slides all the way in. I persoanllly think it was some type of synchronization issue- so attempting this with the slides sitting “womper-jawed” might lead to the issue not being resolved.
slide, slide out
