Old 02-07-2017, 09:16 PM   #1
Slide out grease??
Sorry if this is a dumb question. UT I just bought my first rv and I have 2 slides. My question is should I grease the teeth under the slide out when it's all the way out? I don't know how to describe it but it's the pole under the slide with the gear teeth that I'm referring to. There is nothing on them currently and I don't want to screw anything up. Thanks in advance
Bcaudle89 is offline   Reply With Quote
Old 02-07-2017, 09:18 PM   #2
Crusadernoob's Avatar
I have a can of dry lube just for this, I have one slide that squeaks every now and then, a little spray and all good for a long time!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
Crusadernoob is offline   Reply With Quote
Old 02-07-2017, 09:33 PM   #3
Yes, I use this... https://www.amazon.com/Protect-All-4...rds=slide+lube spray it on, let it dry. It is a dry lube thus will not tend to pick up dirt..
dalford is online now   Reply With Quote
Old 02-07-2017, 10:29 PM   #4
X3. No grease, use dry lube only. Available at most auto parts stores.
slide, slide out
