Originally Posted by youroo
Oh Boy this is a Mess! If you bought it New take it back to the Dealer for "Slide Removal" and repair! The "Hump" on top must be fixed in order for the "Seals/Wipers" to work properly! The Pic with the Slide in the OUT position didn't even bring the "Seals/Wipers" out with it,this is NOT normal either! If bought used,it looks like the PO applied TAR to attempt a Fix? Either way your slide needs to come OUT and start repairing roof portion and New Seals!  Youroo!! Using "303 Protectant" on "Seals/Wipers" is always a needed maintenance issue,but you case is way past that!
Thanks for the feedback Youroo.
The pic with the slide in the OUT position does have the flap out (seals), it may be hard to see in the picture but that white stuff on it was seal conditioner that i put on and still had a bit left at the time i snapped the picture.
I did buy this travel trailer new, so i will contact the dealer ship which i assume should be covered under warranty, never had good experience with warranties as there's usually some fine print or a way out for them but i'll give it a shot.
I will send them pictures and explain that i want the slide out roof repaired and get new seals.
