Old 04-29-2020, 10:41 PM   #21
Maybe Iím confused... are both switches broken off?
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
dalford is online now   Reply With Quote
Old 05-26-2020, 02:11 PM   #22
Found the problem. The relay switch was faulty plus the we need a new battery. Anyone know where to buy a new relay switch for a 2001 Sierra? This is the relay right next to the tongue. It worked enough to get the slide outs out but needs to be replaced.
DEFAYE is offline   Reply With Quote
Old 05-26-2020, 02:19 PM   #23
Head Rambler
Measure the dimensions of the switch and look for an "SPDT, Center Off, Rocker Switch" with those dimensions and you should find one that will work for you.
Gotta go campin!
Old 05-26-2020, 02:42 PM   #24
It is more like a junction box with a reset switch. It has the battery connections on it, under the tongue. We already replaced the rocker switch.
Old 05-26-2020, 03:25 PM   #25
Does it look like this.. https://www.amazon.com/Fastronix-Aut...0524670&sr=8-3
Old 05-29-2020, 10:48 AM   #26
Yes, it does look like that. Now are you saying for my camper (2001 Sierra) I would need the 30 amp relay?
Old 05-29-2020, 03:42 PM   #27
No, that just happened to be the rating selected when I opened that item. Iím not sure what size you require but if you remove it and take it out of the rubber jacket I think it will be labeled on the side as to what amp rating it is.
hydraulic, slide, slide out, switch
