Originally Posted by Bemusdave
I have a Cherokee Arctic Wolf. The wardrobe slider makes a clunking sound when it goes out. When it gets to the fully extended position the clunking noise is quite loud.
Any suggestions?
If it is making the clunking as it is going in and out and not just at the stops in either direction, there is an issue. Only clunking you should ever hear is possibly at the full out or full in position and then as others have said release the button on the first clunk.
If it is clunking while moving in or out then you could have a gear slipping, a chain skipping if it is chain drive, what ever it is, it will only get worse.
