Originally Posted by joejffrs
I can’t see anything except the drive pinion gear. Guess it could be hydraulic but I assumed the motors were electric. Anyway-glad the dry lube will work.
Thanks for your help!
Look on the sides of your slide. Do you see a strip with a worm gear type design. That would be a Schwintec slide control.
It could be something completely different with motor that drive the rack and pinion in and out.
A hydraulic control would be a ram underneath the slide to push it out and to retract it. You would hear the hydraulic pump motor running.
Glad the dry lube will work for you. Do t be shy about spraying it on. Leave the slide out a while to give it time to dry.
2016 Siverback 33IK, Towed 60K+ mile
