Old 05-30-2017, 07:21 PM   #1
Slide Out Problem
Had a great weekend in the RV but after we got home my rear slide won't go out. There's nothing when I hit the toggle switch in or out. No movement, no noise at all. I'm assuming an electrical issue and maybe a fuse somewhere? But, I have no idea where to look. It's a 2008 Lexington GTS 255 DS. The front slide is working fine still. I don't have any books or manuals that show where fuses are located. Any help is greatly appreciated!
jjohn68 is offline   Reply With Quote
Old 06-12-2017, 01:01 PM   #2
Have you looked at the battery box they should be 3 inline fuses there check those also check your panel box to my dad's is in there
jt.jackson is offline   Reply With Quote
Old 06-12-2017, 01:04 PM   #3
I'm having same trouble with one of my slide but fuses are good now trying to figure if there might be reset switches for each of them but don't have a clue as to where to look
Old 06-13-2017, 08:40 PM   #4
grumpy0374's Avatar
Slides not controlled by fuses. They are are controlled thru a mini circuit breaker, one for each slide. Their located in or behind a panel marked Battery Control Center, and should be near the house batteries. The slides are powered by 12 volts, and if the circuit breaker is good, check the condition of your battery. Even if plugged into a 30 amp pedestal, if batteries are bad, slides won't work.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-13-2017, 09:26 PM   #5
bikendan's Avatar
Well, my 2007 HTT's slideout blew its fuse all the time for awhile.
It was a 30 amp fuse just for the slideout.
Old 06-13-2017, 10:09 PM   #6
grumpy0374's Avatar
Don't know what an HTT is, but class c mh use mini circuit breakers not fuses. Maybe older units use fuses, but newer, like my 2012 Lexi use circuit breakers.
There is also a main circuit breaker in the panel that has a small reset button. That may also be a problem, but doubt it since OP stated one of the slides was working.
Grumpy
Old 06-13-2017, 11:40 PM   #7
bikendan's Avatar
HTT is a Hybrid Travel Trailer.
Most travel trailers I know of, have fuses for the slideout.
Newer ones too.
Old 06-14-2017, 04:35 AM   #8
Thanks I've looked everywhere for circuit breakers and have found none I've looked in all compartments and behind fuse panel insid trailer nothing. I have a 31ft 5th wheel with RL and 2 slides in rear. I do know slides are 12 volt not hydrolic. Someone said that they might be limit switches on each slide that may be getting hung but a service center told me they have never heard of it. Idk
Old 06-14-2017, 05:56 AM   #9
I had a fuse under the tongue for each slide that would randomly blow.
Danx2 is offline   Reply With Quote
Old 06-14-2017, 07:43 AM   #10
grumpy0374's Avatar
I was responding to the OP who has a Lexington mh, which, if like mine, uses mini circuit breakers in a seperate Battery Control Center.
Grumpy
Old 06-14-2017, 03:27 PM   #11
I will look there when I get back home this weekend thanks
slide, slide out
