Old 09-27-2020, 01:56 PM   #1
Question Slide out problem
Our 2004 235 Lexington slide out stopped working and is in. No problems with it before - just didn't move, or attempt to move, when we attempted to put if out. Appears there is no power to the OUT - IN switch on the control console. Can't find a fuse or circuit breaker for this, and can't find a wiring diagram either. Other switches on the console are powered OK. Seems like a no power to motor problem. The wiring to the OUT - IN switch seems capable of handling the amperage required for the motor to run, but perhaps there's a relay involved. Anyone have suggestions?
RAY GIB is offline   Reply With Quote
Old 10-01-2020, 06:46 PM   #2
Slide out
The problem with the slide out not moving is absolutely MY OWN Fault ! When installing two new house batteries I inadvertently attached the lead that runs the slide out to ground on the batteries instead of attaching it to the + or positive side where it should be. After fixing that it works just fine! I shuda known better!
Old 10-02-2020, 08:41 AM   #3
SeaDog's Avatar
Glad you found it and thanks for letting the forum know what you corrected. I have found my smart phone works wonders for helping me remember which wires go where lol
Retired Navy
2016 Flagstaff 26 FKWS
slide, slide out
