Old 02-06-2018, 03:25 PM   #21
Updated my signature and profile
2007 Ford F-350 4x4 Lariat Crew Cab 8’ Box SRW 2013 3030RS
ken8246 is offline   Reply With Quote
Old 02-19-2018, 08:31 PM   #22
retireearly's Avatar
I had only one of four rollers contacting properly and it wasn't level. After jacking it up I used a 90 degree screwdriver and added body shims to get all the rollers up and level. Frustrating that this had to be done, but it is right now.Click image for larger version
ID:	162890Click image for larger version
ID:	162891Click image for larger version
2017 Forester 2291S
2015 Honda Accord on Master Tow Dolly
1999 Jeep Cherokee flat tow
retireearly is offline   Reply With Quote
Old 03-02-2018, 07:58 PM   #23
Slide-Out failure
Our 2016 3010DS also experienced "cam-follower bearing" failures. They crushed from either mis-adjustment or possibly too much weight in the overhead storage compartments above the dinette/sofa areas.
I replaced them myself after waiting over 6 months for the dealer to "get me scheduled in".
The original bearings were rated at a very low load specification. I replaced them with much higher rated, same size, bearings. Not an easy task, but tired of waiting on the dealer (they win!)
Ohinaz1970 is offline   Reply With Quote
Old 03-03-2018, 07:32 AM   #24
Edrps's Avatar
Originally Posted by retireearly View Post
I had only one of four rollers contacting properly and it wasn't level. After jacking it up I used a 90 degree screwdriver and added body shims to get all the rollers up and level. Frustrating that this had to be done, but it is right now.Attachment 162890Attachment 162891Attachment 162892
How much did you have to lift it to get at the fasteners. Were the fasteners Phillips? How far did you have to shim it up? Went to the big box store to purchase a right angle screwdriver. I'm not sure if the one I found is small enough. It absolutely amazes me that this kind of bad assembly gets out the door. In my opinion this is not an isolated problem we are having. I imagine there are a lot of these slides out there not properly supported. They work for about a year until the mechanism fails and then FOREST RIVER can wash its hands of it because it's out of warranty. Now it's our problem and as you have found, good luck trying to find a shop that wants to deal with it
Edrps is offline   Reply With Quote
Old 03-06-2018, 11:52 AM   #25
Didn't lift it much, just enough to remove weight so I could put rollers up enough to insure the would carry weight. Yes, they are just regular Phillips screws. I got a small right angle kit at Lowe's, kobalt. Some of the rollers needed a quarter inch, others one eighth, etc. I had a body shim assortment from harbour freight. Took several tries to get it right, but they all roll now.
2017 Forester 2291S
Old 03-06-2018, 12:14 PM   #26
Edrps's Avatar
Thank you.
Old 03-11-2018, 08:46 AM   #27
SimoRandy's Avatar
Send a message via AIM to SimoRandy
Has anyone had problems with the inside of the slide rubbing on the floor? My bedroom slide was scraping and I noticed one side of the bed base (foot of the bed) was dragging on the floor. I assume there is a roller under there? Thought I'd try this forum before taking it apart.
Georgetown 369 XL (2016)
Randy S.
2016 Georgetown XL 369 & 2013 Jeep Wrangler
SimoRandy is offline   Reply With Quote
Old 03-11-2018, 08:58 AM   #28
Mine has rollers on the inside as well, not easy to get at them.
2017 Forester 2291S
Old 04-17-2018, 05:11 PM   #29
Handyman
I have a 2016 Salem Cruise Lite 253RLXL with a Schwintek slide. My problem is the roller are cutting into the bottom of the slide floor. I have been reading and found people having the opposite problem of the rollers not touching. That can be shimmed. I can't find anything on my problem. Any suggestions?
2013 F-150 XLT 5.0 Crew Cab
2009 F-150 King Ranch 5.4 Crew Cab
tfmdgm is offline   Reply With Quote
Old 04-17-2018, 05:34 PM   #30
Edrps's Avatar
It doesn't look like rollers are cutting into bottom from the picture. To me it looks like something on the other side of the wall is doing the cutting. The material on the bottom of the slide does not look like a hard surface. If it is not there should be some sort of indent caused by the rollers. Is the bottom a hard surface?
Old 04-18-2018, 06:55 AM   #31
Handyman
The material on the bottom of the is something like a nylon fabric over wood. There are 3 of the roller doing this. The one in the picture is the worst. I'll look further to see if I can find what's cutting it.
Old 05-06-2018, 11:22 AM   #32
I,m having the same problem. What’s worse is that the wood seems to be slightly rotten from retaining moisture. I plan on fastening an aluminum plate in this area to give the roller something to roll on.
Pjs63 is offline   Reply With Quote
Old 05-06-2018, 03:56 PM   #33
Handyman
After looking at my situation further, it appears that a seam in the plywood is right at the edge of 3 of my rollers. The plywood next to the roller is supported by a floor joist and the plywood that the roller is riding on has no support under it. Therefore, the weight of the slide is pushing the unsupported plywood in. The solutions that I see are: 1. Move the rollers over to ride on the floor joist (almost impossible), 2. Add support for the "flexing" plywood (again, almost impossible), 3. Add a metal plate the width of the slide for the roller to ride on.
Old 05-06-2018, 04:05 PM   #34
Handyman
What make/model trailer do you have?
Old 05-06-2018, 04:38 PM   #35
Berkshire 390QS
NO3putt's Avatar
Many Berkshires have had to put metal plates where the rollers were leaving marks. Skip
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 05-09-2018, 01:50 PM   #36
2012 Chaparral 325MKS
slide
