Has anyone seen a need for slide-out stabilizers to help prevent damage to the slide-outs? Camping World has these on sale and I was looking at them for use as another purpose. While looking over the specs it was noted that these help prevent the bending of the slide-out extension tubes that could occur over time. I never thought of that being a possibility. Has this type of damage been a problem for anyone? I could see it happening if you overloaded a slide, but through normal use, idk.
Steve and Kim
Southern Illinois
2021 Cedar Creek 311RL
2020 F350 SRW Crew Cab
I've thought about these from time to time over the years and as I recall, the consensus was to never use them because they can cause more slide align problems rather than help. If you need more stability in your rig, consider the JT Strongarms or BAL system to help stabilize the whole coach.
__________________ 2016 Wildcat 295RSX - 2015 GMC 2500HD DblCab Duramax/Allison 4x4 Z71 6.6' Bed
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
That's what I thought. If you propped a slide with one of these and then the camper settled onto the stabilizer for some reason that could be a problem.
There are several discussion on the forum regarding this issue. The manufacturers say they are not recommended and that seems to be the general consensus here. The major concern is that should a shift occur, such as a slowly deflating tire, this would put a load on the slide and damage it.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
Camping World does not care what the manufactures state about their products (trailer with slides). Camping World is only out to make a profit by selling a product, regardless if it will damage a trailer or not.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
It is not only Camping World. I have seen these for sale at many RV stores and Dealer shops.
They were once needed many years ago on a few units. Today every manufacturer I know of says DON'T use them.
