Old 09-24-2018, 10:44 AM   #21
Denver To Yuma In 90 Days
Originally Posted by jtatum65 View Post
Oh DUH! It's monday and I a slow on mondays
I edited in a photo in my last post while you were typing...
Shows how the awning is basically useless as an awning.
Here it is again:
JohnD10 is offline   Reply With Quote
Old 09-24-2018, 10:57 AM   #22
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I hope this is the right place for this question. But I have a Shasta 336RL and ordered toppers for all 3 slides per the sizing chart by Solera. But it appears the awning arm next to the living room slide is too close to mount the topper hardware. I have attached a picture of what I am seeing. I am not sure there is way to mount this topper without the awning arm interfering with the slide closing. See attached picture.
Any suggestions will be helpful. As I don't think I want to install the other toppers without this one, as the DW says it will look stupid without all 3.
You may have a problem but I'm no expert.
You'll need just about 3 inches between the awning arm on the side of the trailer and the outer edge (the 3' flange) of the slideout for the awning topper mounting bracket.
From the outside of the slideout you want to add 3 inches for the flange that covers the rubber wiper seal plus 3 inches for the mounting bracket.
ID:	187412   Click image for larger version
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 09-24-2018, 10:58 AM   #23
I am sorry but most of the "Measurements the OP "has listed are for the Material Cloth, the Roller Tube and Mounting Brackets "Add to OAL" If you continue to think a Topper that will clear your "Obstacles "will look good and cover PART of the top of slide, go for it and Please Post Pics! Youroo! !
Old 09-24-2018, 11:17 AM   #24
jtatum65's Avatar
As you can see by my photos in my previous post, for the slide topper fabric to cover the slide roof, there has to be a bit of bracket stick out on each side of the slide flange.
The brackets could be flush if you so desired. The topper would be a bit short but that would certainly be better than none IMHO.
Yea thats what I thinking. I have checked with both Dometic and Carefree and they don't have a better solution either.
Jim & Evelyn Tatum
2018 Shasta Phoenix 336RL FW
2019 Dodge Ram 2500 Big Horn 6.4L 8spd 4x4
Nights Camped 2020 = 36
Nights Camped 2019 = 36
Nights Camped 2018 = 28
jtatum65 is offline   Reply With Quote
Old 09-24-2018, 11:51 AM   #25
Georgia Rally Coordinator
aceinspp's Avatar
Thanks for the info. The Solera toppers coming in plastic sleeve and the size is labelled at both ends. But I understand what your saying. In my case the problem isn't with the incorrect awning size, but more of not enough space between the slide out and the arms of the awning. I am going to have to order another topper that is 2 sizes smaller. The slide out box is 146", that is not including the flanges. The topper that will fit is 145", so now I will order that one.
Hope this does the trick for you as the slide toppers are a great thing to have as mentioned more pros than cons. Good luck. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-38
Old 09-24-2018, 12:24 PM   #26
I have had slide toppers on all my trailers since 1998. Only had one problem with a Micro Burst in Gulf Shores, AL. The storm not only got my slide out topper but 2 stages and over 200 booths at the National Shrimp Fest.
tomrob1161 is offline   Reply With Quote
Old 09-24-2018, 12:29 PM   #27
jtatum65's Avatar
Youroo,
You are correct and I apologize for not providing everyone with complete information to form the best opinions and advise.
The slide out w/ flanges is 152" wide. The slide box is 146" wide
There is approximately 1 inch of space between the slide flange and the awning arm. The topper mfgs do not list the total length of their toppers including tube and mounting hardware.
So I think the Solera topper that has 145" of fabric is the best option at this point. But I am still open to suggestions.
Jim & Evelyn Tatum
Old 09-24-2018, 12:55 PM   #28
I agree that the 145" unit will be your best bet and it'll look right. At least it'll be even on both sides.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-24-2018, 02:47 PM   #29
Youroo,
Ok,now our Box is 145.5 add flanges and the total overall width is 151.5! The overall width of the A&E slide topper Factory Installed Hardware is 159.5 ! NOW we have the same size Slide,do you have anywhere close to 159.5"for equal mounting location? Youroo! !
Old 09-24-2018, 02:58 PM   #30
Anti billowing block
You will need to install the antibillowing device on the side of the camper so you need to be careful where the end bracket is installed. The device is mounted to the movable topper at the end which is very close to the edge of the fabric. Hope this makes sense.
BobSparky is offline   Reply With Quote
Old 09-24-2018, 03:17 PM   #31
jtatum65's Avatar
According to Solera anti-billowing device is not needed.
Jim & Evelyn Tatum
Old 09-24-2018, 05:30 PM   #32
CaptnJohn's Avatar
2 weeks ago on the fringe of Florence toppers survived 50 mph and 70 mph gusts. Some myths never die.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 09-25-2018, 11:20 AM   #33
jtatum65's Avatar
Ok I have ordered the topper I am sure will work for this slide and will post pictures when I have it installed.
In the meantime, I am wondering what can be done if I accidentally strip out one of the screws on the mounting bracket? Not sure how I managed that, as I was being careful not to let this happen. I am installing the 2 other toppers
Jim & Evelyn Tatum
Old 09-25-2018, 02:42 PM   #34
There are several ways to repair a stripped screw hole.
There are inserts that you plug the hole with and reinsert the screw. Screw-It-Again is one.
You can also fill the hole with some good 2-part epoxy and once it dries you can drill and reinsert the screw into it.
If it's in aluminum framing you can use nut-serts to repair it.
Gotta go campin!
Old 09-25-2018, 02:45 PM   #35
Nailz's Avatar
Some possible options; One size larger self tapper, Fill hole with toothpicks & wood glue, use two part epoxy to fill the hole?
I almost made the same mistake, had the drill in drill mode and not screw mode with clutch, caught my mistake in time.
C
2018 FR XLR Nitro 35VL5
2013 Ford F250 SRW 4x4 6.7L, Air Lift 5K Ultimate,
B&W Turnoverball Gooseneck Hitch, Andersen Ultimate Aluminum 5th Wheel Connection
2008 Honda Goldwing, U.S. Army Veteran
Nailz is offline   Reply With Quote
Old 09-25-2018, 03:33 PM   #36
Heres something to be carefully thought out. You can put spacers behind the slide topper mounting brackets just deep enough to clear the closed awning bracket. Keep in mind maximum opening of the topper fabric. Before installing anything,,, open the slide,,then open the canopy and see if the canopy arm passes thru the place where the topper support would be. If it does you're a cooked goose. If it doesn't, then you just have to remember to "ALWAYS" open the slide out "BEFORE" you open the awning. Just My McGyver thoughts.LOL!!
Lee Pedrick is offline   Reply With Quote
Old 09-25-2018, 03:36 PM   #37
Its a real shame the designers of that model didn't forsee that
Old 09-25-2018, 04:44 PM   #38
When installing my toppers (Carefree) I stripped a screw for one of the brackets that mounted on the slide. I noticed the marking on the head was different than the others. It turned out that that there were two different size screws provided with the same head size. One for the rail that mounted on the trailer, and a larger size for the brackets that mounted on the slide. I got a small screw mixed in with the larger screws. When I put the larger screw in, it didnít strip out.
As someone mentioned, try a larger screw.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 09-25-2018, 05:09 PM   #39
Daycruiser's Avatar
A topper that sags or billows is an improperly installed/maintained topper. Reset the recoil on the topper to keep it taught. Never had a problem with any topper I've ever had on any RV I've had in any weather condition.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 10-01-2018, 08:45 PM   #40
JohnD,
I have had toppers on the last 2 campers, a travel trailer and a FW, I never once had any issues with my toppers, nor did I have to pull in my slides during windy days or night.
But thanks for your input.
grayfox is offline   Reply With Quote
slide, slide out
