Old 06-21-2020, 07:22 PM   #1
Ron045's Avatar
Slide out trim replacement
I was hoping someone could help me identify the proper name/material for this slide out trim. As you can see from the pics it is cracking and coming out. It feels like a rubbery plastic. Pretty flexible. But this slide gets a lot of sun. So it's now brittle and breaking apart.
If anyone has replaced this before and you can also ID a vendor or any install lessons learned it would be greatly appreciated.
2017 Flagstaff Shamrock 23KISS (or Rockwood Roo equivalent)
Big slide on the left
Thanks!
Ron
ID:	232031   Click image for larger version
ID:	232032   Click image for larger version
ID:	232033   Click image for larger version
Ron & Family
5th Year Seniors, Almost Empty Nesters
2021-14 Nights, 2020-10 Nights, 2019-25 Nights, 2018-30 Nights, 2017-23 Nights
2017 Shamrock 23IKSS
2016 Lincoln Navigator L, 4x4, 4.10
Ron045 is offline   Reply With Quote
Old 06-21-2020, 07:45 PM   #2
paverdave's Avatar
Hey Ron, there was a thread recently on here about trim, here it is...
https://www.forestriverforums.com/fo...ff-208881.html
Dave...Northern Nevada
2018 Rockwood 8299bs
2007 GMC 2500HD SLT short bed w/gravity flow75 gallon Fuel Tank
Firestone Airbag Ride Rite system
paverdave is offline   Reply With Quote
Old 06-21-2020, 08:55 PM   #3
Now a "Top Member"
EdJunior's Avatar
Ron, does this trim sit in a channel, like the pictures in the link paverdave posted, or does this go around the edge of the slide, as a seal? It's a little hard to tell from your pictures.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
Old 06-21-2020, 09:17 PM   #4
Ron045's Avatar
It's a channel on the face of the slide. The large black frame is like a picture frame that outlines the whole slide. This trim is on the inside of that frame. Pic added.
RonClick image for larger version
Ron & Family
Old 06-22-2020, 12:39 PM   #5
OldJarHead's Avatar
Thanks!
Ron
Replaced recently on my bedroom slide. Very easy and cheap!
Black Vinyl 1" Insert Molding... https://www.amazon.com/dp/B077H26H2Z...p_mob_ap_share
2015 RAM 3500 Cummins LB 4x4
2018 Rockwood Signature Ultra Lite 8328BS
OldJarHead is offline   Reply With Quote
Old 06-22-2020, 01:38 PM   #6
Ron045's Avatar
Thanks. Ordered today. I measured 36 feet, so the 35 ft was no good. Saw the 100 was only $3 more than 50 ft, so ordered the extra length.
Ron & Family
Old 06-22-2020, 02:44 PM   #7
Craig and Carol's Avatar
Trim
Posted this very question on the RPOD forum about an hour ago. Thanks for sharing the solution. Question...at the corners the trim looks as if it has to be mitered, did you use an adhesive to attach the vertical pieces with the horizontal pieces or does it not have to be that exact...thinking water leakage and aesthetics for my ocd?
Craig-retired Teacher o/t Blind
Carol-retired Legal Administrative assistant
Spot and Sam-the lovable miscreants
RPOD 180 and Ford XLT 150 5.0
Craig and Carol is offline   Reply With Quote
Old 06-22-2020, 04:05 PM   #8
Now a "Top Member"
EdJunior's Avatar
RonAttachment 232039
Thanks Ron. The reason I asked is because mine needs replaced also, but mine appears to be different. Mine looks like this (my 5th wheel is a 2010 model...it appears they have changed the way the do the slide seals).
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
Old 06-22-2020, 08:16 PM   #9
89tta500's Avatar
Send a message via AIM to 89tta500 Send a message via MSN to 89tta500
If this is what seals the slide out to the side wall when it is in, it is called bulb seal. There are several versions so you may have to measure it before you order.
https://www.amazon.com/s?k=rv+bulb+s...f=nb_sb_noss_1
2017 SOB
2002 GMC SIERRA CCLB 8.1L
89tta500 is offline   Reply With Quote
Old 06-22-2020, 08:46 PM   #10
bubbles's Avatar
Attachment 232085
I think this is what Ron is seeking.
Old 06-23-2020, 10:58 AM   #11
Ron045's Avatar
Yes Bubbles... That is exactly the piece. And here it is, ordered and delivered from Kentucky to Pennsylvania in 13 hours. Transportation Logistics simply amazes me sometimes.Click image for larger version
Ron & Family
Old 06-23-2020, 11:29 AM   #12
bubbles's Avatar
Yes Bubbles... That is exactly the piece. And here it is, ordered and delivered from Kentucky to Pennsylvania in 13 hours. Transportation Logistics simply amazes me sometimes.Attachment 232165
My post was for EdJunior. He seemed somewhat confused.
Old 06-23-2020, 11:52 AM   #13
Ron045's Avatar
I know... I was just adding to the validation and at the same time I read your post the mailman dropped it off.
Ron & Family
Old 06-23-2020, 08:31 PM   #14
Now a "Top Member"
EdJunior's Avatar
Gotcha Bubbles. I'll have to look a little closer at mine, not that you pointed them out. But the black seal trim is what I need to replace on mine.
Ron, that's cool that you found yours and got it at your door in the span of two days! Incredible.
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
Old 06-28-2020, 12:35 PM   #15
Ron045's Avatar
Trim Replaced
I was able to remove and replace my trim. Super simple. The longest part of the job was trying to find a lost screw that dropped.
Here is how I did it.
Have Fun!
Ron
Ron & Family
replacement, slide, slide out
