Old 09-22-2022, 06:24 PM   #1
Slide out wiper seal
I have a 2019 Wildcat, WCT321RLI and need to replace wiper seals. I contacted Forest River to obtain Part number. cbiddle@forestriverinc.com answered with-in a day with the following:
"These are replacement seals; the original ones are no longer available.
This is a one-sided seal where the original was a double sided (interior and exterior).
So, if both sides need replaced you need to order 16 per side. We use these on all primetime units.
Please take note that there are 2-part numbers for the top and side of the slide out.
F100163006 Seal, Wipe, Single Bulb, Flip 'N Seal 2 3/4" (600' per box) Top
F100163005 Seal, Wipe, Single Bulb, Flip 'N Seal 2" (1000' per box) Side"
Does anyone have experience replacing these, and know where I might find them to purchase. It appears it may cost $500 for about 40'. any help or suggestions would be appreciated.
Name:	RV seal 1.jpg
ShawneeOkie is offline   Reply With Quote
Old 09-22-2022, 07:10 PM   #2
bikendan's Avatar
Moved thread from the General Community Discussion section to the Slideouts sub-forum, in the Tech and Repair section since the OP's questions are specific to Slideouts and are not General questions.
Sent from my SM-G781U using Forest River Forums mobile app
Old 09-22-2022, 07:17 PM   #3
I painfully paid about 290 bucks for a 14 foot piece of double wiper seal when all I needed was about 5 feet. Wow seems odd you have to replace seals this soon.
Sunseeker16 is offline   Reply With Quote
Old 09-23-2022, 11:36 PM   #4
chris1911's Avatar
So they are saying you can replace the double flap type with single flap? The double flap kind wraps around the wall. If you use single on the inside and outside, it would seem the the wall between them would not be protected. The cost difference is huge though. With single flap, i could do the entire slide (inside and out) for $200. Double flap, like it came with, would be $700.
https://visitedstatesmap.com/image/ALARFLGAMONCSCTNsm.jpg
chris1911 is offline   Reply With Quote
Old 09-24-2022, 09:35 AM   #5
httntheroad's Avatar
Steel rubber has everything you need. Click image for larger version
ID:	279628Click image for larger version
httntheroad is online now   Reply With Quote
seal, slide, slide out
