Old 04-15-2024, 11:11 PM   #1
Slide Out Won't Align
I purchased a 2022 Sabre Cobalt FLL 5th Wheel two years ago. The kitchen's slide when retracted does not close all the way.. See attached picture
How do I fix? Thank you!
Ksaunders is offline   Reply With Quote
Old 04-16-2024, 12:47 AM   #2
bikendan's Avatar
What slide system does it have?
Rack and pinion, Schwintek, etc?
Old 04-16-2024, 10:36 AM   #3
Slide Out is a Lippert Schwintek
Old 04-16-2024, 12:15 PM   #4
Are you sure it's Schwintek? The bottom sticking out as the picture seems to show is classic rack and pinion also made by Lippert. Does the other end also stick out at the bottom?
wheelin14 is offline   Reply With Quote
Old 04-16-2024, 12:27 PM   #5
Jonnybow's Avatar
That's not your slide that's the issue, it's the warped panel with the light on it. I can see it right below the vent and the panel is concave.
I'm spending my kid's inheritance
Jonnybow is offline   Reply With Quote
Old 04-16-2024, 12:50 PM   #6
Yes it looks like something hit the side of your camper
G37x is offline   Reply With Quote
Old 04-16-2024, 01:11 PM   #7
It's not retracting on the other side too. I'll get a picture of the other side.
Old 04-16-2024, 03:19 PM   #8
bikendan's Avatar
A Schwintek slide system will have an upper and lower track, on each side of the slideout. There is a motor on each side.
If the slide is truly out of alignment, due to the motors, you have to find the slideout controller. There is no standard location for it.
slide, slide out
