Old 05-14-2021, 09:19 AM   #1
Slide Seal Repair WCT312RLI
Is there a way to repair slide seals that are splitting, like using Flex seal or something similar. see photo
Name:	InkedRV seal 2_LI.jpg
ShawneeOkie is offline   Reply With Quote
Old 05-14-2021, 12:56 PM   #2
The best way to fix them is to replace them. I haven't heard of anyone using a 'tape' to fix them, but something like Eternabond or Flex Seal may work as a temporary patch, but it wouldn't be permanent.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 05-14-2021, 07:24 PM   #3
Any idea of what it cost to replace them, is this something only a dealer can do. This trailer is only a couple years old and not used very much before I got it. Wonder if it is a common problem on Wildcat Trailers.
Old 05-14-2021, 08:39 PM   #4
llamb's Avatar
Check here to see if you can find the seal. Likely $100 or so depending on how much you need to replace.
Steel Rubber Products - RV Slide Outs
Larry
2021 Riverstone Legacy 42FSKG
2016 RAM 3500 DRW
llamb is offline   Reply With Quote
Old 05-16-2021, 03:10 PM   #5
Thanks for info
Wow thanks, looks like it would work, I just need to see if I can get the old one out. It appears to have a metal strip holding it in place and not sure how the metal strip is held in place. Good info
Old 05-16-2021, 03:19 PM   #6
llamb's Avatar
Lot of square drive screws (Robertson head or something like that) and sometimes rivets.
Larry
2016 RAM 3500 DRW
Old 05-17-2021, 08:06 AM   #7
Witch Doctor's Avatar
It looks like itís the inside seal, is there also a outside seal? If there is I would tape it. Are you getting water intrusion from it? I do not like those slides with the wire, your hardest part to replace it will be that wire that has to come out to replace the seal or really the wipe. You have to get the right one, you might need to order it from a dealer
Coachmen M/H
Concord
2018 / 300 DSC
repair, seal, slide
