Old 08-01-2020, 09:26 AM   #1
Slide Seal Replacement
Anyone have I any ideas how I repair this slide seal?
Thanks in advance...
Russell
dangerruss is offline   Reply With Quote
Old 08-01-2020, 04:45 PM   #2
Head Rambler
The white plastic insert pulls out of the trim channel and then you remove the screws and the trim channel and seal rubber comes off. You buy new seal rubber and replace it.
You can also buy new trim insert and replace that too.
Gotta go campin!
Old 08-01-2020, 05:03 PM   #3
I have purchased the white plastic insert before. I assume you can get the rubber seal at the same place. Thanks.
Old 08-01-2020, 05:06 PM   #4
Head Rambler
You should be able to. Just get a measurement and make sure the profile is the same if it has a lip or bulb.
Gotta go campin!
Old 08-01-2020, 07:27 PM   #5
Lip or bulb. I'm a newbie. Exactly what are you speaking too?
Old 08-01-2020, 07:49 PM   #6
Head Rambler
Some slide seals have a bulb built into the rubber piece or has a lip formed into one edge, but it doesn't look like yours has either. From the picture yours looks like a flat piece of rubber.
Gotta go campin!
replacement, seal, slide
