Originally Posted by Alberta8311ss
Thanks, your more optimistic than I am. I don't see how adjustments at the far end will affect how it sits square in the opening when it seems the slide floor or trailer floor is out. But I will give it a try, thanks for the advice!
If you have concerns that something is wrong with the floor?...(floor issue unlikely on trailer or slide)
In your first pic, you showed the bottom of the slide...
Remove the bottom sweep seal to get a look in there.
Lift the carpet under the slide, is a butter knife stuck in there, debris?
Is there damage on the interior?
Carpet pulling strings?
Linoleum damage?
Factory could have just screwed bottom sweep crooked?
What is the issue inside?
Water infiltration?
The only thing we are doing on the outside is getting the sweeper seals to engage without getting crushed.
My slides (4) all needed adjusted on my new rig.
The wiper seals were getting crushed on one side or the other. The dealer fixed this after I noticed on my PDI. Squared up the slide boxes.
Once my rig was delivered, I noticed the slides were not flush with the floor and needed to extend further to sit flush. The mobile tech took a few hours to adjust that issue.
All is well now.
My previous rig, I had to adjust the slides myself, just like you are doing, you will get it.
Raise one side, lower the other. Lower one side, raise the other then lower or raise both. Bottom line, engage the seals without crushing or getting the slide box hung up.
