Originally Posted by gbaldwin
Sure.... Bottom line, the fuse labeled for the slide was a 15 amp... Which I checked and changed first thing.
After checking switch, manually backing out slide motor, and relay at drive motor... thinking that the fuse for the slide drive motor should be 30 amp.
Fuses were mislabeled from manufacturer.... a blown 30 amp discovered, replaced, and solved.
Learning!!
I like a happy ending...
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
