Old 08-22-2017, 08:47 AM   #1
Slide Stuck - Ideas?
Have the Surveyor Model 200MBLE - It has the dinette slide. 2016 model.
Slide worked fine this weekend. Home to unload yesterday... attempt to run slide out and NOTHING. Wouldn't move. No straining motor sound. NOTHING. Checked the 15 amp fuse in my main breaker/fuse panel. Looked fine but changed anyway for good measure. I am plugged into shore power (120). Other 12 v electrical working fine. Battery charged overnight. Still no movement or noise from the motor.
My guess its something electrical. I am fairly new to this and have never tried the hand crank to run the slide out. Thought this might be a start? Read somewhere though that this might (hand crank) not be the best next step?? Plan to try and figure it out this evening. Thoughts or ideas greatly appreciated.
gbaldwin is offline   Reply With Quote
Old 08-22-2017, 08:52 AM   #2
ejohnson1144's Avatar
I had a crimp connector fall off of feed wire under my couch.
Mabe the same with your slide wires.
Sent from my LG-H910 using Forest River Forums mobile app
ejohnson1144 is offline   Reply With Quote
Old 08-22-2017, 08:54 AM   #3
fonzie's Avatar
What is full model # of your trailer?
Fonzie
Old 08-22-2017, 09:01 AM   #4
Oaklevel's Avatar
Just thoughts
1) Is the trailer level
2) check fuses (I know you said you did) replace fuse anyway
3) Check for loose wires at motor, switch and in between etc.
4) Power at switch ? If the motor is 12V do you have power there? when switch is engaged.
Good Luck
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-22-2017, 09:26 AM   #5
200 MBLE and it is 2016... not 2015
Old 08-22-2017, 09:40 AM   #6
Yep Level .. Did change fuse...
Gotta find the motor? Guessing maybe under slide? Might need to hand open to get to it?
AND Not sure about power at switch. Do have power at all other switches in the switch panel (awning, lights.....) . Thanks will
Old 08-22-2017, 10:16 AM   #7
Iwannacamp's Avatar
Some of the slides are easy to manually operate...some are not. If it's an easy one maybe operating manually will jump start the motor and all will be good again(unicorns, ferries, flowers, etc..)
2017 Puma 297RLSS
Old 08-22-2017, 11:46 AM   #8
Carl17's Avatar
RELAY
We had rely next to motor come out of socket and the motor would not work . A real pain to get to on main slide just had to push it in and magic it work. good luck.
Carl & Bette
2018 Leprechaun
NEW YORK
Carl17 is offline   Reply With Quote
Old 08-22-2017, 12:34 PM   #9
jdstrubel's Avatar
Help has arrived
I love how QUICKLY members respond when someone sends out an SOS signal..... GREAT! Nice to know someone is out there when the need arises... God Bless - Debbie
2017 Flagstaff Super Lite - 832IKBS - Diamond Package
2006 GMC Sierra 2500HD
Been an RV owner since 2003
jdstrubel is offline   Reply With Quote
Old 08-22-2017, 12:41 PM   #10
Hmm.... my first step is to locate that motor then. Only been at this 7-8 months. I guess that motor would be somewheere in the slide?
Old 08-22-2017, 12:51 PM   #11
Just a quick thought. I have had a lot of slide problems with my full length wall slide. After a lot of searching for the solution to this problem, I found that I did not have enough "juice" in my battery to move the slide.
My problem appears to be that the converter does not put out enough amps to bring my battery up to 12.4 volts. This happens especially if I am in one place only a day or two. If I am on pedestal or generator power, I grab my 10 amp battery charger, hook it up to my house batteries, and give it 5 minutes or so. My slide works fine after that.
These new slides need a lot of juice to go out or in. I will probably replace my converter with a better one and see if that solves the problem.
WayneLee is offline   Reply With Quote
Old 08-22-2017, 01:02 PM   #12
To bad they didn't use a socket with a retainer clamp would have never fell out
Old 08-22-2017, 01:14 PM   #13
DouglasReid's Avatar
The slideout may have its own in-line fuse. Look at the wires near yoru battery and see if there are any inline fuses and check them.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 08-22-2017, 01:37 PM   #14
Slide Stuck
Same thing happened to me. Check the wires on your wall switch. Mine came loose.
davduck53 is offline   Reply With Quote
Old 08-22-2017, 06:32 PM   #15
Stormrider151's Avatar
Does your battery have a full charge? I know you said your plugged in but I think your slide will pull amperage from the battery. And as someone else mentioned, there may be an inline breaker just behind your battery on the frame that may have tripped. It has a tiny button on it you have to press to reset.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 08-22-2017, 08:34 PM   #16
Thanks all for suggestions.... Went thru them all in order.... Problem SOLVED!!!
Old 08-22-2017, 08:52 PM   #17
B and B's Avatar
Oh Please tell......
Old 08-22-2017, 08:59 PM   #18
bikendan's Avatar
Yes, what was the solution?
Old 08-22-2017, 09:12 PM   #19
Sure.... Bottom line, the fuse labeled for the slide was a 15 amp... Which I checked and changed first thing.
After checking switch, manually backing out slide motor, and relay at drive motor... thinking that the fuse for the slide drive motor should be 30 amp.
Fuses were mislabeled from manufacturer.... a blown 30 amp discovered, replaced, and solved.
Learning!!
Old 08-23-2017, 12:08 AM   #20
We pulled in to a Walmart the other night and the slides didn't open. No noise, nothing. Under the front of the trailer are 2 30 amp fuse holders. Road debris hit one of those holders and knocked the top right off and blew the fuse. I put a new fuse in it and patched up the fuse holder and the slides worked.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
slide
