Old 03-18-2020, 03:46 PM   #1
CJMAFT
Slide stuck out 2017 Coachmen Pursuit 33bh
I have a 2017 Coachmen Pursuit and the slide is stuck out. The large slide on the drivers side is stuck. I am not sure if there there is a fuse box for it or a reset bottom. Where may it be located in the coach?
thanks
Cmonteiro is offline   Reply With Quote
Old 03-19-2020, 07:57 AM   #2
SeaDog's Avatar
A couple of things you need to check as you work thru this problem. 1. are your coach batteries at 100% 2. are you plugged in or running the generator. 3. Most slides do have an inline resettable fuse/circuit breaker it looks like a little box on the main cable leading to the slide make sure the tis reset. 4. do you hear anything when you hit the switch and have you checked for power at the switch.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-19-2020, 10:02 AM   #3
Look in your outside compartment, especially those close to the slide in question, possibly on the top of the compartment and you should see the reset boxes. Can you hear the motor running or is it completely dead? I had a shear pin break on my rear slide and could hear the motor running, but no movement.
Hope this helps.
2014 Coachman Mirada 29 DSSE
2009 Jeep Wrangler Unlimited
jhlady is online now   Reply With Quote
Old 03-20-2020, 01:50 AM   #4
CJMAFT
No I don’t hear anything. My other slide is working with no issues. It seems to be completely dead.
Old 03-20-2020, 01:53 AM   #5
CJMAFT
I am plugged in and the other slide is working fine. I just can’t seem to find this reset box. I’ll spent more time looking.
Thank you
Old 03-20-2020, 12:06 PM   #6
https://www.forestriverforums.com/fo...ds-190799.html
Sounds like a blown fuse...My secondary fuse panel was underneath the drawer next to the main fuse panel...pics and thread attached.
Cha-Chi is offline   Reply With Quote
Old 03-20-2020, 12:58 PM   #7
I have a 2016 Leprechaun, and even the manufacturer could not help me find the fuses for my slides. I ended finding them by chance in the back of a storage compartment behind a plastic cover. 2 screws, and there they were.
leblancdave is offline   Reply With Quote
Old 03-22-2020, 05:40 PM   #8
CJMAFT
Thanks you guys.
This is what I have next to my batteries with no fuses that I can tell.
coachmen, slide
