Old 09-06-2021, 08:38 AM   #1
sas7001's Avatar
Question Slide Tilts When Starting Out
Newbie here with a 2006 Lexington 283gts. Never having an RV before, I wasn't sure if this motion is ordinary. All 3 slides do the same thing. When they begin sliding out, they tilt downward, like the top goes first, then move evenly out until extended. When they are retracted, they move evenly back in then tilt up and in place. They perform well otherwise. I just thought they should move straight out with no tilting action.
Steve & Cindy
2006 Lexington 283GTS w/Ford 450 chassis
Since Fall 2021
sas7001 is offline   Reply With Quote
Old 09-06-2021, 08:50 AM   #2
NMWildcat's Avatar
Ordinary. Normal.
Scott and Liz - Southern NM
Old 09-06-2021, 09:07 AM   #3
SeaDog's Avatar
That motion is cause by the slide box sitting on rollers or slides so as it starts to move it tilts toward the ground as the flange moves away from the sidewall, and then when the top of the inside flange contacts the inside wall it tilts up until the bottom flange contest the wall to give you a flush or nearly so floor opposite happens on retraction.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-06-2021, 09:24 AM   #4
sas7001's Avatar
Thumbs up Whew...
Thanks to SeaDog and Wildcat. That makes me feel better.
Steve & Cindy
Since Fall 2021
Old 09-06-2021, 09:39 AM   #5
Georgia Rally Coordinator
aceinspp's Avatar
Just what the slide is made to do. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-55
Old 09-06-2021, 01:38 PM   #6
Freetyme's Avatar
The first slide operation and I too thought somethings not right. It's all normal. Now if it doesn't slide evenly on both sides, that's a problem that needs attention.
Freetyme is offline   Reply With Quote
Old 09-06-2021, 03:41 PM   #7
I have two of six that do that, too. As long as there's no dragging on the finished floor, I think its very normal.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 09-06-2021, 04:58 PM   #8
Witch Doctor's Avatar
I have a motor home with the schwintec [spelling] system. My two slides do not dip at all, when I had a 5 er and a tag along the slides did that. Now mine go straight out and come straight in. So I donít know what system you have. But mine do not rock or dip at all.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-06-2021, 05:01 PM   #9
My slide is similar. Seems normal.
2020 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equalizer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
Old 09-08-2021, 08:42 PM   #10
Slide tilting
Only my big font slide with steel tracks on the bottom does that. The mechanics say to expect it, however, it has rollers underneath than can become loose and even fall out. I had to have a couple of rollers tightened back up and even a couple replaced. So you might want to have them checked next time your are in for servicing. But even when the rollers are secure, the slide still rock and rolls some.
Attached is a sample of what your rollers could look like...
hikerjohn7 is offline   Reply With Quote
Old 09-09-2021, 05:13 AM   #11
whirledpeaz's Avatar
If it's a rack and pinion flush floor slide, it's supposed to look like it's going to fall out when coming in or out. Now a schwintek slide or other above floor slide should go straight out and back in.
2020 Rockwood UltraLite 2608BS
2017 F250
whirledpeaz is offline   Reply With Quote
Old 09-10-2021, 06:49 AM   #12
xí2 On this statement, he has a M/H not a 5 er or tag along, Iím pretty sure itís a Schwimtec system. I do believe thatís all Coachmen uses in that M/H.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-10-2021, 07:20 AM   #13
NMWildcat's Avatar
The OP has a 2006 unit. If there was anybody using Schwintek then, it wasn't many. I think the first time I saw Schwintek on anything was around 2010. So my bet is he doesn't have a Schwintek, and also the slides seem to be working fine
Old 09-10-2021, 07:57 AM   #14
that could be very true, I tried to look on line at a unit but couldnít get good enough view, I was looking for the rails. Itís a class C so I donít know how they could put a rack and pinion system in, I know classAís have some rack and pinion but I have never seen it on a class C , Iím not sure what he is calling a dip but he very well may not have the garbage Schwintec.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-16-2021, 06:54 PM   #15
johnandval's Avatar
Ordinary. Normal.
Normal is a setting on a washer and dryer.
I keep expecting the whole slide to fall out each time I retract it.
It maybe sop for this slide assembly but my older 2011 Kodiak Kitchen slide never tipped like this and there was much more weight on that slide.
It does make me wonder about life expectancy of my current trailer.
johnandval is offline   Reply With Quote
Old 09-16-2021, 07:10 PM   #16
I have a Lexington as well,although the 300SS has only one big slide, it works the same. I contacted Lippert, the manufacturer of the slide,and they sent me information on the slide operation, that is the way it is designed.
Seemed odd to me as well
Celticrider is offline   Reply With Quote
Old 09-16-2021, 07:11 PM   #17
NMWildcat's Avatar
Have no idea what your implications or goals are with your statements.
I have three slides on my current RV. 2 tilt when coming in or going out, one slides w/o tilting. All normal.
If your slides tilt, but function normally time and time again, then chances are this is normal for your slide type, as it is for the OP.
If you are concerned about your slide falling out, I've heard wearing a tin foil hat helps it become normal
Old 09-17-2021, 01:00 AM   #18
Jim S JR's Avatar
Yep normal...you shouldn't use the slide outs unless completely pushed out.
Jim S JR is offline   Reply With Quote
Old 09-17-2021, 07:45 AM   #19
Lowandslow
Eagleslink's Avatar
I have the same exact unit. Agree, this is normal operation.
Feel free to message me if you have other questions on your Lexington,
Maybe I can assist ☺️
Eagleslink is offline   Reply With Quote
Old 09-17-2021, 11:34 AM   #20
With our 2007 Sunseeker 3100SS, the slide starts moving out at the bottom first, which makes us want to push out on the top to help get it moving. This means that the slide starts by tilting up, which is the opposite of all the above descriptions.
Underdog is offline   Reply With Quote
slide
