Originally Posted by bikendan
I owned a 2007 Roo 23SS for 10 years. The only problem I had with the super slide, was that it started blowing the 30 amp fuse that was located under the trailer, along the frame.
The slide motor is located under the couch. I suspect wiring or switch issues. Have you used the supplied crank to put the slide out?
I replace both batteries with new ones and checked all fuses.... all showed good. Tried the switch, nothing on "OUT", retraction "IN" started to work then quit. Checked 30 amp fuse near frame... it was blown. Replaced, attempted again with same results. Blown fuse again and replaced.
I'm thinking it's a short somewhere or my Slideout motor is starting to fail and putting too much load, then blowing the fuse? Did you find out what was causing your problem when your fuse kept blowing?
Yes I've used the manual crank to extend and retract the slide.
Thanks for your time and input.
2009 Roo 23ss
2014 Nissan Armada
Former Trailer - '99 Coleman Niagara
Me, Wife, 5 daughters, 4 grandkids
