Old 05-07-2016, 05:31 PM   #1
Slide wires hanging down
When my slide is closed the wire harness lays on top of tires how do I keep this from happening I just got it home from the dealer
Brightowl is offline   Reply With Quote
Old 05-07-2016, 05:35 PM   #2
Iwannacamp's Avatar
My old 5er had an arm that folded in and out as the slide went in/out. The wire was attached to that. I have seen some with a spring on the wire to keep tight when retracted.
2017 Puma 297RLSS
Old 05-07-2016, 05:39 PM   #3
fonzie's Avatar
yes normally there is a support for the wires.....
Fonzie
Old 05-07-2016, 06:12 PM   #4
As said, there's a support that keeps the wiring from sagging when the slide is extended or retracted. It would help if you told us the make and model of your unit as different units have different supports. By knowing the unit we may be able to tell you what to look for, and possibly how to fix it and save yourself a trip back to the dealer.
Gotta go campin!
Old 05-07-2016, 06:34 PM   #5
It is a 2016 Salem hemisphere 24rk travel trailer
Old 05-07-2016, 08:01 PM   #6
Our Salem has a piece of plastic turned vertical with a loop molded on one end thru a post to hold it that way. It has several pieces that fit over the vertical piece and stick out to one side. These pieces have a hole in them. the wire loom goes thru the holes and are supported by them. The loom hangers will slide on the vertical track. If yours is like that, all the loom hangers may have slid to one end or have slid so there's a large gap between them allowing the wire loom to sag.
Gotta go campin!
Old 05-07-2016, 08:55 PM   #7
crunchman12001's Avatar
The part that broke is called Flex Guard.
Take it to the dealer under warranty or buy it from the Lippert store.
http://store.lci1.com/flex-guard-kits
2015 F-250 FX4
Old 05-08-2016, 11:43 AM   #8
As crunchman said, they are flex guards. Mine broke on both slides and I replaced them, but I anticipate them breaking again! Not a great design, I've seen that some people just attach small hinges at the breaks and problem solved! I'll try that when these ones break!
atcla is offline   Reply With Quote
Old 05-08-2016, 11:54 AM   #9
fonzie's Avatar
Lippert store
Lippert Components RV Accessories|Storage and Convenience
Fonzie
Old 05-08-2016, 01:13 PM   #10
wz3mo's Avatar
This. Mine kept breaking where the flex guard attached to the slide. I attached a hinge on the end of the flex guard then attached to slide at original spot, fixed!
wz3mo is offline   Reply With Quote
Old 05-09-2016, 09:02 AM   #11
litgrep's Avatar
Mine broke after a year. There was enough slack in it to reattach it. Wasn't worth a 180 mile 1 way trip to dealer. WHEN it breaks again I'll find a new way. The plastic doesn't seem like it has the durability to make it through travels. So far only the long slide on my right side had the problem. Left slide doesn't extend as far.
litgrep is offline   Reply With Quote
Old 05-09-2016, 09:18 AM   #12
Mine lasted less than a dozen slide extensions (maybe 3 weeks). Temporarily hung out of the way with Ty-raps and took it back to the dealer. New plastic loom and rerouted it a different pathway. Still works a year later, but I inspect it before I move the Vibe every time and expect it to happen again. I might just might take it off. It's just for the marker light anyway!
2016 Vibe 268RKS
2015 Chev 2500HD
Mewcasa is offline   Reply With Quote
Old 05-09-2016, 09:20 AM   #13
(Dry Huunday)
DreiHunde's Avatar
Yep! I just did the same thing last week! 1 1/2 hinge works perfect! Best thing is for less than 2 dollars it comes with a spare!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 05-09-2016, 09:48 AM   #14
flex guard
DreiHunde,
I have the same issue. There is another thread around here that explains how one member installed a $2.00 hinge to create a pivot point. I want to try this fix.
Do you or anyone else have a picture or drawing/sketch of how the hinge should be installed? Which way does the hinge pivot? Does the hinge get bolted into the broken plastic? etc. etc.
Any hint on how to get started would be a big help.
Thanks so much,
Jim
jpaskell is offline   Reply With Quote
Old 05-09-2016, 10:06 AM   #15
(Dry Huunday)
DreiHunde's Avatar
Originally Posted by jpaskell View Post
DreiHunde,
Thanks so much,
Jim
I don't have a picture(can post later though)
But mine broke where the strap mounts with 2 screws to the trailer frame. So what I did was remove the broken piece from the frame, then attach the new hinge to the strap using small nuts and bolts (drilling two holes in the plastic is easy.)
Last step is take those two previously removed screws and attach the hinge to the frame. Works great!
I'll post a pic later when I get to the camper if no one else finds one before!
Beau & Sue
FurKid Express
Old 05-09-2016, 10:13 AM   #16
(Dry Huunday)
DreiHunde's Avatar
This thread has pictures of the repair NCRadioman did.
http://www.forestriverforums.com/for...ard-38573.html
Beau & Sue
FurKid Express
Old 05-09-2016, 10:35 AM   #17
flex guard
DreiHunde,
Thanks so much for the reply. I appreciate it. I'm going to give it a try and if I get it backwards, I'll just do it again in the opposite direction. Good news is the hinges come two in a pack.
Thanks again,
Jim
Old 05-09-2016, 04:04 PM   #18
(Dry Huunday)
DreiHunde's Avatar
Here is my repair. I forgot to mention that I reused the broken tab as a spacer between the new hinge and the frame.
Beau & Sue
FurKid Express
Old 05-09-2016, 04:45 PM   #19
flex guard
DreiHunde,
Got it, now I better understand what I'm looking at.
Thanks so much for the help and kind consideration. I appreciate your efforts.
Jim
Old 05-10-2016, 07:55 AM   #20
(Dry Huunday)
DreiHunde's Avatar
Teamwork!!!
Beau & Sue
FurKid Express
slide
