Old 08-08-2020, 05:19 PM   #1
slide wont go out or in, 2109S
i just got back from a week camping trip. When I set up, my slide wouldnt go out. I used the hand crank and it worked easily. When it came time to pack up, the slide still wont work. Again, i used the hand crank.
Where should i start? Switch? Wires? Motor?
i was hooked up to power. I tried to use the battery instead. Still no luck. Got it home, still no luck.
Thanks for any advice you have!
Jill
Jill Hromek is offline   Reply With Quote
Old 08-08-2020, 05:44 PM   #2
bikendan's Avatar
Start with the fuses.
Old 08-09-2020, 08:13 PM   #3
After doing more research, and reading a reply to another slide issue, i found a fuse under the RV. and wouldnt you know, it was blown. I replaced that fuse and the slide works!
Thank you for all the knowledge that i am finding in this group! You guys are amazing.
Jill
210, 2109s, slide
