Old 04-15-2017, 02:27 PM   #1
Slideout controller
I have a Coachmen 2002 5th wheel 340IKS. The controller (DN13819) is obsolete and there is no replacement for it. What I was wondering is could I use a reversible solenoid like one that works a winch ( something like a reversing solenoid contact relay 6 terminal)? I tried a different controller and it only worked for 2 trips before it went out. I am desperate and need help. Thank you in advance.
danmonz7 is offline   Reply With Quote
Old 04-15-2017, 02:38 PM   #2
Left Coast
Gama Electronics RF 12V1PR-ASL will do the trick...
Old 07-30-2017, 02:53 PM   #3
is this an easy conversion? i need the same part. also do you know the part number of the limiter switch that stops the slide from going to far in or out?
Rebel1448 is offline   Reply With Quote
Old 07-31-2017, 08:26 AM   #4
The part number is DN13819. I could not find anything that worked good enough so I used a reversible winch solenoid and watch when slide is extended or retracted. This works great and is heavy duty enough to handle couch slideout.
Old 07-31-2017, 10:36 AM   #5
thanks, do you have any info on the stop/limit switches?
Old 07-31-2017, 11:36 AM   #6
Sorry I don not have any info on the limiters and I could not find anything on them.
Old 08-01-2017, 08:48 AM   #7
i found the limiter switch part number. A-20GQ-B7-K.
Thank you all for your help.
controller, slide
