Slideout mechanical components access
2016 3010DS, large slide won't open "tight" to the wall; found 1/2 of a roller bearing laying on the coach floor under the booth area.
Question: how do you access the mechanical components to assess the problem? Only access seems to be the 2 or 3 inch gap between the bottom edge of the slide and the coach floor. Must be something I'm missing. Surely you don't have to remove the slide from the coach?
