Old 07-29-2011, 01:18 PM   #1
Slideout repair
Can anyone tell me how to get the platform out that holds the sildeout motor assy in place? I have one that has a broken piece and the rod will not turn. also is there a way to lock a slide in place when it is broken and will slide in and out by pushing and pulling.
tedslope1 is offline   Reply With Quote
Old 07-29-2011, 03:12 PM   #2
Boyd's Avatar
More information please.
What is the date, make and model of your rig?
Use a slide-out lock bar to keep your slide in place.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 07-30-2011, 01:14 AM   #3
2006 sunseeker by forest River
Old 07-30-2011, 07:43 AM   #4
Boyd's Avatar
Your 2006 Sunseeker by Forest River looks exactly like my 2010 Freelander Dreamer, just different decals. So, with that I'll make a guess that the slideout system is the same. I think this is the manual you are looking for.
Your slideout is "free" to slide in and out if the shear pins that connect the inner and outer drive shaft have been snapped. Refer to this manual (Manual for above floor slide-out system. http://www.eco-rv.com/scripts/pdfretail/get.php?id=365 ) It is a difficult, on-your-belly fix but it is possible. You can also replace the shear pins from the cargo hold but in either case you are working almost blind. Having someone else to work with you, one inside, one on the outside makes the job a lot easier.
Also check to make sure the motor bolts are secure/tight. Loose bolts on the motor may lead to broken driveshaft shear pins.
