Old 08-19-2020, 07:49 AM   #1
Slides work and dont work
I had changed house batteries in July and had to reset the bunk over driver's seat to have up and down stops reset.
Do i need to reset the slides, as since battery chandge they work sometimes and don't work til i have turn ignition key on then off? not sure what to do.
They eventually work, but not the way it was. I always have shore power on when operating slide, and of course jacks down, parking brake on.
any suggestions. Need to find controller and reset?
DAVE SZ is offline   Reply With Quote
Old 08-19-2020, 09:28 AM   #2
It might help to know which RV you have. It sounds like a motorhome, but no guess as to which one it may be.
You're description of the intermittent operation sounds kinda like a limit switch not making reliably.
Gotta go campin!
Old 08-24-2020, 06:11 PM   #3
I have a 2019 Mirada 35os
Almost 2 years and s as sways have hacks down when put slides out or in
I have had to to turn key on and off several times for either slide to work
Once that is good they work til I drive home or to campground and want to put slides out
Must have to do with ignition switch?
Just started to happen
Is there a cable under steering wheel to. Heck?
slide
