Old 07-09-2020, 01:37 PM   #1
muddyrode's Avatar
Slugish slide outs
we have a 2017 sandpiper with hydraulic slide out and hydraulic level up systemthey run off the system
the battery is new showing 13.6 volts and the converting is showing it is putting out 13.6 volts to the battery we are plugged into shore power 50 amps and yes it is wired correctly
when we moving the slides you have to stop and restart a couple of times to get it to go completely in or out acts like it needs to recharge the battery briefly
when using the level up system you have to do it manually and the system with shut itself off a as if the battery was low it show 13.6 volts ??
if you try to use the auto the system will shut off
does anyone know what the pump should be drawing for amps
looking for any suggestions and i have checked all of the connections and grounds
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 07-09-2020, 01:54 PM   #2
NMWildcat's Avatar
This is exactly how our hydraulic system was acting. With ours it was the 50amp auto reset breaker continually tripping and resetting. We would start bringing the slides in or the levelers up, and it would stop. Wait a few seconds, the breaker would auto reset, we could resume for a bit. Repeat until you were done.
Lippert said to replace the 50amp auto reset breaker with an 80amp. No more problems since then. There was a tech bulletin on it, but I can't find it now.
Check your auto reset breaker to see what size it is. If you already have the 80amp, then start checking hydraulic pump amp draw, batteries, and breaker. Breakers wear out just like everything else.
As far as battery power; the 13.6 is the converter output. You need to disconnect the batteries and load test them to see if they are still good. Weak or bad batteries can also cause breakers/fuses to trip.
Scott and Liz - Southern NM
Old 07-09-2020, 02:11 PM   #3
muddyrode's Avatar
the battery was about three years old but tested ok but we did replace it anyway so the battery is new and it is fully changred
when working the slids it actully does not stop but it starts to go so slow just barly moving so if you let off on the switch and then just push it back on it speeds back up for about the next 12 inches so you need to do that through out the three slides
but i will look at the fuse
Old 07-09-2020, 03:32 PM   #4
NMWildcat's Avatar
I've always had good luck calling Lippert tech support. They have helped me diagnose several things, and even sent free parts occasionally!
Old 07-10-2020, 09:15 AM   #5
muddyrode's Avatar
thanks i hope it find time this weekend to work on i will post my findings
Old 07-20-2020, 07:54 AM   #6
muddyrode's Avatar
UP Date
well finally had time to replace the fuse, well i actually added another 80 amp that just runs the hydraulic motor as the original 50 amp had another connector off of it and it was part of the hot lead buss bar.
so i had to run the battery lead to the 80 amp and then add another connection to the hot buss bar
but upon trying the slides they work as should with no hesitation i will be trying the landing gear this week
thanks NMwildcat
Old 07-20-2020, 08:42 AM   #7
NMWildcat's Avatar
Congrats on getting it going again! Always a good day when things work like they are supposed to.
And thanks for getting back to us on the outcome.
Happy RVing!
slide, slide out
