Old 03-23-2020, 10:14 PM   #1
Small Gap in slide out seal
Name:	Slide length.jpg
Name:	Slide gap measure.jpg
2018 Geo Pro 19FBS - This weekend I noticed a small gap beginning to form in the corner of my slide out's seal. Despite the pics this gap is on the top corner of the slide out. I was told by the dealership this is NOT a warrantied repair and is considered a maintenance issue. Is there a recommended process for this repair and/or recommended adhesive/sealant I should be using? Sorry, can't seem to properly orient the pics, but I think you get the idea. TIA
CPC659 is offline   Reply With Quote
Old 03-24-2020, 12:12 PM   #2
The first thought I had was how the hell.....? My second thought was push it back from the inside , but really you can't do that. So my final thought would be to try a self leveling sealer to try and put in there, but damn it would have to be pretty thick to not run all over. Maybe a couple small layers of roofing caulk? Force it in a little bit with a very small hole in the nozzle, let it dry. make a slightly bigger hole in the nozzle and repeat...then keep repeating until you get a flush finish with edge....Again, I am just guessing here....It's probably what I would do....
David 01 is offline   Reply With Quote
Old 03-24-2020, 01:01 PM   #3
The pictures are messed up. What you're seeing is a flat surface on TOP of the slide. I can't seem to rotate the pictures and they've somehow uploaded sideways. I've talked to Forest River and so far they're saying Eternabond tape is likely the best route. Thanks!
slide, slide out, seal
