Old 07-24-2017, 09:37 PM   #1
Strange noise from slide out on road bumps
I have a 2016 Mirada 35LS that has a noise that sounds like rubbing your hand over an inflated balloon coming from the top of the large slide out when you are on a bumpy or uneven road. I have looked everywhere for some type of rubbing but can find nothing. Any ideas?
Dvanzee is offline   Reply With Quote
Old 07-24-2017, 09:48 PM   #2
My first thought is the seal on the slide and slight movement while driving. Tried any lubrication on the seals ?
TheWolfPaq82 is offline   Reply With Quote
Old 07-24-2017, 10:16 PM   #3
Yes, lubricated the gaskets that seals to the body of the coach. Is there a seal that is toward the top and not easily visible?
Old 07-25-2017, 04:25 PM   #4
BigHomey's Avatar
I have the same sound (pretty loud at times) and it seems to be coming from the front of my large front slide. I tried lubricating the gasket and it did not help. I am now leaning towards the slide cover stop on the front. It could be too loose or too tight. I have not tried adjusting it yet, but when I get home from this trip, I am going to mess around with it.
Here is a picture of the same stop on the rear slide. It shows a little better because of the lighter colors.
AL
2016 Coachmen Mirada 35KB
2016 Jeep Cherokee 75th Ann. Ed.
2007 Corvette Convertible
1997 F-350 CC PSD
BigHomey is offline   Reply With Quote
Old 07-25-2017, 04:46 PM   #5
Searching for a fix
I have the same setup. The rear has a plastic plate cover on the coach but the front does not. I adjusted the screw that butts up against the plate but no differences. Will keep trying until I find the problem because the noise is driving me crazy. Let me know if you discover anything.
Dave V
noise, slide, slide out
