Originally Posted by spower
Question....has anybody here removed the gear pack on a through frame slide out? I lifted inner rail some, rollers on gear pack are loose but gear itself is still super tight, is this right? I need to make an adjustment so just need to loosen gear pack, take one bolt out to pivot gear pack down i.e. disengaging the gear. I'm just worried how tight it is, if I pop it out (not even sure I can) will i get it back in? Thx!
Hello? Anybody??
I've replaced both gear clusters on my slide.
With it extended enough for working room I placed a jack under the outer end if the rail and lifted about an inch. Gear cluster is easily removed.
Good time to lube bushing bearings in cluster with a drying type silicone lube. 3-In-One Slide Lube works great for me.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
