Old 07-18-2020, 01:35 PM   #41
HK3
So I got everything pulled out and we’ve had a lot of rain...so I think I’ve figured out that the leaks are actually coming from the bottom and corners. Not from the top or even the windows. I am thinking at one point the water may have come in through the front plastic splashing/panel cause I can see it’s been recaulked. Then once it was a problem it continued to stay damp by water seeping in at the bottom corners. Problem is that the framing looks to be damaged pretty bad as well...so the job is growing bigger by the minute... any and all inputs welcome/appreciated.
ID:	234177   Click image for larger version
ID:	234178   Click image for larger version
ID:	234179   Click image for larger version
ID:	234180   Click image for larger version
ID:	234182   Click image for larger version
ID:	234183   Click image for larger version
ID:	234184   Click image for larger version
HK3 is offline   Reply With Quote
Old 07-23-2020, 01:46 PM   #42
Sorry to see that much damage. It looks like it had been leaking for awhile. That outside trim piece can be a troublesome leak spot. Also the outside bottom rail on the slide can also leak. Please keep updating the forum on your progress and what you do as the information could become helpful to others in the future!
billybigrigger is offline   Reply With Quote
Old 07-23-2020, 02:08 PM   #43
Is you refergerator drain tube out side of trailer? This is a source of water if fridge is on same side of trailer. Mine ran to the bathroom floor.
Thomas ho is offline   Reply With Quote
