Old 03-23-2020, 12:55 PM   #1
What is this?
Both my slide outs have a rod welded to a place which extends into a hole of the main frame and extends into the belly pan area. .
As far as I can see it does not connect to anything.
Maybe it hits a sensor or something when fully retracted?
cryptopivot is offline   Reply With Quote
Old 03-23-2020, 01:54 PM   #2
Flybob's Avatar
Most likely that is the manual open/close mechanism for the slide. There should be a crank handle somewhere in the RV that fits into a keyed end.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-23-2020, 02:26 PM   #3
Did you look at pics?
That's not it
Old 03-23-2020, 02:28 PM   #4
nomad297's Avatar
That's not it
No pics to look at.
Bruce
Old 03-23-2020, 02:57 PM   #5
Oaklevel's Avatar
Pictures would help. No pictures.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 03-23-2020, 08:50 PM   #6
My apologies, must have deleted the link upon submission.
https://photos.app.goo.gl/UxxrrbTqj1NfLDBn8
Old 03-23-2020, 08:51 PM   #7
Did not send for some reason.
Old 03-23-2020, 09:30 PM   #8
Looks like it might be a support for the slide wiring with the zip ties holding up a piece of wire loom.
My slide uses the same mechanism but I don't recall seeing that rod. The wiring is controlled by a flat piece of plastic that pivots on one end and is secured to the outside of the slide, kind of folding back as the slide is retracted.
Looks like your wiring is merely supported by this "curtain rod" that retracts into the frame when the slide itself is retracted.
Just my guess.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 03-23-2020, 10:01 PM   #9
Mr Towed's Avatar
To put a picture directly in your post go to the section below where it says ADDITIONAL OPTIONS and under the Attach Files section click the box that says Manage Attachments. You can then upload you picture and it will show up right in your post so you don't have to worry about hosting it somewhere and people don't have to click a link to see it.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:15Nights
Mr Towed is offline   Reply With Quote
Old 03-23-2020, 10:41 PM   #10
I donít know but looking at your pics what are you lubing your slide with? Looks like grease? i Suggest you use a dry lube because if that is grease it will pick lots of dirt and grime that will not be good long term for the mechanisms. JMHO...
2016 Siverback 33IK, Towed 30K+ miles
Andersen Ultimate Hitch
Old 03-23-2020, 10:47 PM   #11
Oh by the way, welcome to the forum from the Space Coast..
Old 03-23-2020, 11:29 PM   #12
onetonford's Avatar
Mine had those rods and it was for the wires that are coiled they didn't use them on mine because they were too close to the wheels. I decided to remove them because the bracket on the slide was way to close to the wheel for my comfort I cut the brackets off and removed the rods then plugged the holes.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 03-24-2020, 01:26 PM   #13
Great info! Thanks for the responses.
Yes, it is grease, the racks was heavily rusted as was the frame. Unbelievable amount of rust. I have since scraped all rust off the frame using wire brushes and scrapers. I then painted all with Por-15 (amazing stuff)!
I am very happy it the outcome.
I will in fact now remove all the grease from the rack and pinions and attempt to remove any remaining debris from them.
Old 03-24-2020, 04:44 PM   #14
I use this on my slides and pinion gear and teeth..
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old 03-24-2020, 05:15 PM   #15
Flybob's Avatar
That's not it
No pics
TST Tire Monitors
2 100W solar panels
