With the slide extended pin the topper tube and then bring the slide in a few inches this will relieve the pressure on the topper fabric, you should then be able to push the fabric spline back into position and use a zip screw to secure at least one end of it in place. Then run the slide back out and remove the pin. Like has been said a pic is a better way to get an answer. JMHO
Retired Navy
2016 Flagstaff 26 FKWS
