Old 09-30-2022, 10:17 PM   #1
csc
csc's Avatar
White piece of plastic on top of slide outawning
Have a 2022 Flagstaff Micro Lite couples coach. I've noticed this summer that when the living room slide is out fully , there's a white plastic tube that has worked its way out on the top of the roller on the awning. Tried , but unsuccessful in pushing it back to its proper position. Thanks for your advice.
csc is offline   Reply With Quote
Old 09-30-2022, 11:54 PM   #2
bikendan's Avatar
Pics are often more helpful than descriptions.
Old 10-03-2022, 09:34 AM   #3
SeaDog's Avatar
With the slide extended pin the topper tube and then bring the slide in a few inches this will relieve the pressure on the topper fabric, you should then be able to push the fabric spline back into position and use a zip screw to secure at least one end of it in place. Then run the slide back out and remove the pin. Like has been said a pic is a better way to get an answer. JMHO
Retired Navy
2016 Flagstaff 26 FKWS
awning, slide, slide out
