Old 06-28-2017, 11:59 AM   #21
Originally Posted by D W View Post
The remote "CONTROLLER" bypasses the manual switch. As I stated earlier, check the switch connections and the switch contacts. Certainly appears that's where your fault is.
I certainly agree but have already checked the connections at the switch. They were well-connected but I disconnected/reconnected to be sure. Had no effect.
Charleston, SC
2016 Silverado 1500 LTZ
2016 Wildwood 27RKSS
seakayaker is offline   Reply With Quote
Old 06-28-2017, 02:00 PM   #22
It's probably the contacts inside the switch burnt, so they aren't making a good connection.
Gotta go campin!
Old 06-29-2017, 12:18 PM   #23
There's no visible problem at the contacts but it's definitely a problem either with the switch, wiring between switch and motor, or grounding. At least it's not the motor and at least it opens/closes fine with the remote!
Will get an electrician out there in the coming weeks to look at it.
Charleston, SC
Old 06-29-2017, 07:57 PM   #24
Jumper the wires on the switch and see if it works. You can probably replace the switch if needed.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 07-18-2017, 11:17 AM   #25
I determined the voltage across the switch drops from about 13V to about 5V whenever I engage the switch. Would this indicate a bad switch? Slide opens fine using the remote.
Charleston, SC
Old 07-18-2017, 11:21 AM   #26
m35a2's Avatar
The voltage across the switch should drop to 0 when you engage the switch.
So yeah that switch is no bueno.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
m35a2 is offline   Reply With Quote
Old 07-18-2017, 03:43 PM   #27
Originally Posted by saltyman View Post
sounds like your in/out switch is intermittent. Mine was not making a good contact on the come in side. I tighten the lug contacts and it has worked fine.
Nany Nany Na Na
saltyman is offline   Reply With Quote
slide, wildwood
