Originally Posted by ldmc
That is my concern. I can pull back the outside wiper seal and stick my fingers into the inside. So that is telling me the slides need some adjustments.
Has anyone ever adjusted their slides?
How about from the inside? Can you stick your finger behind the facia and the inside wall around you slide? That is your inner seal that should be tight against the wall.
I took pics below.
This first pic is of slide just as you go in the door on our 33IK. The slide is partially in and I can reach out and grab the slider seal.
The 2nd pic is the inside seal of the slide, behind the facia. It is curved and foam backed. This seals against inside wall of the RV.
The 3rd pic is the slide fully extended. It is flush against the wall. Could not get a dollar to slip in there, even though they slip out of my hand way to easily.. I degress....
If your inside facia is tight against your inside wall you can't slide out any further. If you have a gap then you need adjustment.
