Old 05-31-2018, 05:57 AM   #21
Wolverine 1945's Avatar
Originally Posted by DKRITTER View Post
Supposed to be 107 Saturday in Fort Worth Saturday, y'all!!!
You can have it y'all !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-31-2018, 06:03 AM   #22
if you are going to be mostly on 50amp 'full 100amp service' most of the time, at least in the 'hot' months, then YES, get the third AC unit... it will never hurt!
now, if you don't see 50amp RV resorts/parks too often, then NO, don't, since you won't have enough typical power to do anything else while running on the generator, and 30amp campground/park service won't be hardly enough to run two, much less three.
The Turners...
formerFR is offline   Reply With Quote
Old 05-31-2018, 06:07 AM   #23
Why not get a portable ac unit and use that to do a quick cool down?
cmysstailights is offline   Reply With Quote
Old 05-31-2018, 06:23 AM   #24
Or a dehumidifier ???
Old 05-31-2018, 06:35 AM   #25
Humidity isn't the issue in west Texas.
markbeezley is offline   Reply With Quote
Old 05-31-2018, 07:29 AM   #26
We got 3 air conditioners on our Spartan and multiple salesmen tried talking us out of it. One said, “if I add it, don’t call me when you’re popping breakers.”
A proper install comes with a Power/Electric Management System which sheds loads if you start getting close to your amp limitation.
Without that, my hard-wired Progressive Industries display shows my wife and I what each leg is carrying. We keep each leg at less than 50amps. We did pop the breaker a couple of times at the campsite pedastal.
We recently needed to manage down to 30amps and do it the same way. We watch the EMS display and manage to that. We’ve been running 2 A/Cs without issue for a week now.
Thanks Doug.
I was actually wondering more about what happens when you adapt down to be on a 30a service so I'm glad you addressed that. Three are out of the question at that point for sure.
As mentioned, I suppose it really has more to do with where you use your R/V. Here in the North East, we rarely use one A/C let alone three and 50a services at campgrounds are like hen's teeth.
Days Camped: '18=51 '19=58 '20=110 '21=94
air conditioner
