Old 11-01-2018, 04:21 PM   #21
i'm currently in a 30 amp park, with a 50 converter
they told me not to run more than one of my air conditioners,
because it could trip something [lose power] for me, as well as some neighbors
marc
2018 forest river Cardinal 3350 rlx 5th wheel
2018 ford super duty 350, 2 door, SRW
FL-mph21 is offline   Reply With Quote
Old 11-01-2018, 07:23 PM   #22
It's OK, but as you said don't run both a/c or your electric water heater with 1 a/c
tomrob1161 is offline   Reply With Quote
Old 11-01-2018, 11:15 PM   #23
Herk7769's Avatar
We have had reports here of several dogbone adapters that only sent the current to one leg. They were not defective, that was how they were made.
I can't tell you the reasoning behind that nor do I think I'd want mine that way but that was how that particular manufacturer chose to manufacture them.
I do not recall if it was mentioned who the manufacturer was.
You said "we"... Who is we and who is reporting?
The reason "they" said not to run both ACs on 30 amps is that the start up amps on 2 ACs can exceed 40 amps. The run amps on 2 ACs is about 24 amps.
HAM CALLSIGN - KC3FFW
Old 11-02-2018, 12:06 AM   #24
I have a 2017 Cedar Creek Silverback 29IK and I run it on 30 amp circuits most of the time. I usually do not run the front AC at night. The water heater is usually on propane. The frig is on electric and everything works great. I have tripped the circuit breaker on my generator when dry camping though.
Grumpy7159 is offline   Reply With Quote
Old 11-02-2018, 12:40 PM   #25
Herk7769's Avatar
Originally Posted by Livin the Life View Post
[/I][/B][/U][/U]
Tried to use discount code above for purchase and it did not work, said it was not found. ???????????????
Well crud. Looks like we were costing them too much money. It did not work for me now either.
Still worth it IMO.
Old 11-02-2018, 01:44 PM   #26
30 amp running on a 50 circuit?
I hope this is not a stupid question. How about the reverse? I know there are converter plugs on Amazon that will allow you to plug into a 50 amp circuit. I do not plan on adding any additional load on my 30 amp trailer but I am wondering if there are any advantages or disadvantages to using the 50 amp side when both are available?
Rockwood 2018 Mini lite 2304KS
Avalanche 2500
Nathan 18 is offline   Reply With Quote
Old 11-02-2018, 01:59 PM   #27
llr
No advantage to the 50A other then it may have less wear. I would suggest to get the adapter so you have an option if the 30A is bad or loose also I have heard of someplace being 50A only.
TT 2021 Grand Design 2800BH
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2017 F150 6.5' bed 3.5 Eco-boost
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 11-02-2018, 02:03 PM   #28
Herk7769's Avatar
Well, since most campers are still 30 amps, the 30 amp plug gets used more often. They are typically looser and fail more often.
On the other hand, using the 50 amp side leaves your 30 amp cord exposed to the potential of higher current (due to connection problems perhaps) before the first 30 amp protection at the main in your panel.
There will never be more load in your camper since your 30 amp main breaker will prevent that by tripping.
Old 11-02-2018, 05:02 PM   #29
Still worth it IMO.
Just who is this 'we' that was costing them too much money?
LOL! LOL!
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 11-02-2018, 05:54 PM   #30
B and B's Avatar
Originally Posted by 1984fireball View Post
Check and see. You will likely find that the only thing connected to the other leg of the 50 amp is the bedroom AC. And you will not be able to run it because there is no power to that breaker. And maybe a washer/dryer. This is the main, if not only reason for the additional amps in most 5ers. At least in mine.
That is incorrect. The 30 to 50 amp dogbone ties both sides together making everything work. Just can not use everything.
Old 11-08-2018, 07:22 PM   #31
30amp outlet
A 30 amp service supplies 3600 watts. Your appliances should show watts usage.
Arkansas Windjammer is offline   Reply With Quote
Old 11-08-2018, 07:39 PM   #32
If you don't remember Green Acres, search Google. Here Oliver explains to Lisa how she can use only certain appliances at the same time in their home.
https://youtu.be/WGPMadwqPKQ
hardinrob is offline   Reply With Quote
Old 11-08-2018, 08:12 PM   #33
Herk7769's Avatar
Got this back from Micro-Air
Hi Lou,
Yes, That discount code expired due to no activity, please feel free to use the “EASYPROMO” discount code for a $25.00 savings on the EasyStart™ 364 (3-ton) Soft Starter (115V-only RV A/C (-X20-IP)).
Thanks!
Sales Administration.
Old 11-08-2018, 08:40 PM   #34
Yes, verify that it is wired as a 2 pole and not a single Pole or you will only.get power to one side of your Camper! Experienced this situation on Labor Weekend this year!
Greg R. is offline   Reply With Quote
Old 11-08-2018, 10:16 PM   #35
YOU GET IT!
I am laying here in Houston, 72F, 98% humidity, watching me 55 in tv, AC running @ 68 F, cool and dry with my 50 amp plugged into my 30 adapter...My #2 AC is turned off. Cold front coming in and drop temps into 40s and I will run my electric fireplace no issues...
Don
US Army Infantry Retired
Texas Hill Country
Cedar Creek Silverback 29RE
'19 F 350 CC, LB King Ranch Ultimate
17 Oaks is offline   Reply With Quote
Old 11-09-2018, 05:48 AM   #36
This easy mod allows you to monitor the total AC amps being used so you don't trip any breakers.
https://www.ebay.com/itm/Tester-AC13...53.m2749.l2649
Get two; one for each incoming leg.
The donut goes on one 50 amp wire that attaches to the main 50 amp breaker. My panel was straight down and made wiring it with 4 conductor solid telephone cable easy.
I love this! But you said you put the donut on one leg. What do you do, do you split the main 50A RV cord and tie it in there? Curious how to put the coil into the line and where.
Also, did you put the display in the wall in your RV?
MOODMAN is offline   Reply With Quote
Old 11-09-2018, 06:24 AM   #37
Hi Lou,
Thanks!
Herk is this "EASYPROMO" just for You or can the "WE People" use it also? Thanks,Youroo!!
Old 11-09-2018, 07:06 AM   #38
Go back and read HERK's post #6. You must buy 2 for a 50 amp service.
One donut for each hot leg.
Old 11-09-2018, 09:41 AM   #39
Send a message via AIM to Davidnanna Send a message via MSN to Davidnanna
50 to 30 AMP
In short, yes. Just be careful not to overload the system. With that said, I was given the following little chart when I started RV'ing. Maybe it will help you as well...
RV Item Electrical Draw
Coffee maker - 8.3 amps
Converter - 8 amps
Hair dryer - 9 to 12 amps
Microwave - 13 amps
Refrigerator - 2.8 amps
Roof a/c 13.5 amps
TV - 1.5 amps
Toaster - 8 to 10 amps
VCR - 2 amps
Electric skillet- 6 to 12 amps
David Friedberg
Tampa, Florida
USAF Retired Captain and Law Enforcement Officer
2016 Berkshire XLT 43b (diesel pusher)
Davidnanna is offline   Reply With Quote
Old 11-09-2018, 10:02 AM   #40
wmtire's Avatar
You can put it on the legs L1 and L2 where there are split at the distribution panel of the RV going into the main circuit breaker. Lou stated such in post #6.
2011 Flagstaff 831 RLBSS
Life is about changing perspectives and priorities: I used to worry if one of my hairs was out of place, now I don't care if they both are.
50 amp
