Old 11-13-2018, 08:17 AM   #1
A/C Units Freezing in 2018 CRS
Hi Cedar Creek owners. I have a 2018 Cedar Creek CRS Destination Trailer parked on an RV pad in South (hot and humid) Florida. The A/C units are freezing up, and then blowing ice out the cooling vents. I had a mobile technician come out and reseal all of the suction side ducting and tighten down the lag bolts to prevent exterior humid air from being sucked in.
The problem still exists.
Does anyone have similar problems.
Please help.
Rob
Subcrit is offline   Reply With Quote
Old 11-13-2018, 08:27 AM   #2
Tx2Stepn's Avatar
Please help.
Rob
You might check the volts your getting from the power pedistal. Mine has frozen a couple of times and when I checked the volts at the pedestal was low. I have also heard that running it on low has caused the problem for others or too much humidity.
2012 Ram 3500 Cummins - 2018 Wildcat 29RKP
2000 Ford F-250 V10 - 2017 Catalina Trailblazer 26TH
2007 Rockwood Freedom Popup
Tx2Stepn Yorkies
Tx2Stepn is offline   Reply With Quote
Old 11-13-2018, 08:45 AM   #3
Flybob's Avatar
Check your filter and air flow. If it is very humid when you start the AC, low air flow can cause the fins to freeze up. If you have a dump valve, open it when you start the AC in a humid environment and once the humidity goes down some close it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-13-2018, 08:55 AM   #4
When the tech sealed up the ducting did he make sure the partition between the supply and return was sealed up and correctly in place?
Also did he make sure that the freeze coil was in the correct place against the evap coils?
One thing you can do is take a few registers down and hold your phone up in the duct point it both ways and take a few pics to see if the ducts are clogged, loose or crushed.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 11-13-2018, 02:21 PM   #5
You might check the drain holes up top. I had one freeze up, it was sucking up the water in pan.
boatcat AH6NR is offline   Reply With Quote
Old 11-13-2018, 02:39 PM   #6
I have a Wildwood DLX with a similar problem. I used a mirror and flashlight to look down the ceiling ducts and found a constriction in the area where the bump in the roof met the flat portion. I snaked a couple pieces of 2 inch compartment hose to the bend (side by side). This open things up a little and have had no more icing issues. Compartment hoses look like vacuum cleaner hoses with a coiled spring inside to keep from kinking.
bbbymac is offline   Reply With Quote
Old 11-13-2018, 03:34 PM   #7
x2 on FlyBob's advice. Camping around Houston in the summer requires high airflow. Run only on Hi air flow and use the "air dump" instead of the ducts.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
